ConnectionCookie Object
The ConnectionCookie object represents the dialup connection.
The following table lists the members provided by the ConnectionCookie object.
Methods |
Description |
RevokeCookie |
Revokes a connection cookie. |
This object is returned by the RequestConnection method.
Use the ConnectionCookie object to close a connection.
The following example closes the connection right after it has been established.
myconn = SiteKiosk.Dialup.RequestConnection("reason", true, true);
myconn.RevokeCookie();
