CreateBounceSlide Method
The CreateBounceSlide method creates a bounce slide effect.
[obj=] SiteKiosk.Effects.CreateBounceSlide()
Returns a BounceSlide object that handles the bounce slide effect.
The following example creates a BounceSlide object and starts the slide.
myslide.StartPos = 0;
myslide.EndPos = 300;
myslide.Rate = 100;
myslide.Duration = 2000;
myslide.Start();
function UpdatePosition(pos)
sldiv.style.pixelTop = parseInt(pos);
