CreateSmoothSlide Method
The CreateSmoothSlide method creates a slide effect.
[obj=] SiteKiosk.Effects.CreateSmoothSlide()
Returns a SmoothSlide object that handles the smooth slide effect.
The following example creates a SmoothSlide object and starts the slide.
myslide.StartPos = 0;
myslide.EndPos = 200;
myslide.Rate = 100;
myslide.Duration = 2000;
myslide.Start();
function UpdatePosition(pos)
