SmoothSlide Object
The SmoothSlide object handles the smooth slide effect.
The following table lists the members provided by the SmoothSlide object.
Properties |
Description |
Duration |
Duration of the slide effect. |
EndPos |
End position of the slide effect. |
Position |
Position of the slide effect. |
Rate |
Rate of the slide effect. |
StartPos |
Start position of the slide effect. |
Methods |
Description |
Start |
Starts the slide effect. |
Stop |
Stops the slide effect. |
Events |
Description |
OnStart |
Fires when the slide is started. |
OnStop |
Fires when the slide is stopped. |
OnUpdatePosition |
Fires when the position changes. |
This object is returned by the CreateSmoothSlide method.
Use the SmoothSlide object to define the settings of the slide effect.
The following example shows the functionality of the slide effect.
myslide.StartPos = 0;
myslide.EndPos = 470;
myslide.Rate = 100;
myslide.Duration = 2000;
myslide.OnUpdatePosition = OnUpdatePosition;
myslide.OnStart = OnStart;
myslide.OnStop = OnStop;
function OnUpdatePosition(pos)
function OnStart()
id_slst.innerHTML = "Status: started";
function OnStop()
id_slst.innerHTML = "Status: stopped";
switchstartend();
function startslide()
myslide.Start();
function switchstartend()
sldummy = myslide.StartPos;
myslide.StartPos = myslide.EndPos;
myslide.EndPos = sldummy;
align="center">
<tr><td bgcolor="f8f8f8">
effect. For example the sliding SiteKiosk progressbar is
based on this object.
</td></tr>
<pre>
<div id="sldiv" style="position:relative;left:0;">
logosrc = SiteKiosk.SiteKioskDirectory;
logosrc += "skins/Default/img/background/logo.gif";
document.writeln("<img src='" + logosrc + "'>");
<br>
<span style="color:#cc3300;" id="id_slst">Status: stopped</span>
</pre>
</td></tr>
</table>
<div align="center">
<a href="javascript:startslide()">
Start slide
</a>
