IsFolder Property
The IsFolder property indicates if the favorite is a folder.
[bool=] SiteKiosk.Favorites.Item(index).IsFolder
Boolean value that retrieves the isfolder state.
The following example determines if the first existing favorite is a folder and shows it in an alert window.
alert(SiteKiosk.Favorites.Item(1).IsFolder);
