FavoriteInfo Object
The FavoriteInfo object provides information about an existing favorite.
    The following table lists the members provided by the FavoriteInfo object.
    Members
    Properties Description
    IsFolder If the favorite is a folder.
    IsFromSession If the favorite has been created in the current session.
    Name Name of the favorite.
    URL URL of the favorite.
    Methods Description
    Delete Deletes the favorite.
    This object is returned by the Item method. Use the FavoriteInfo object to receive information about an favorite.
    The following example shows the name of the first existing favorite in an alert window.
    alert(SiteKiosk.Favorites.Item(1).Name);
