IsFromSession Property
The IsFromSession property indicates if the favorite has been created in the current session.
    [bool=] SiteKiosk.Favorites.Item(index).IsFromSession
    Boolean value that retrieves the isfromsession state.
    The following example determines if the first existing favorite has been created in the current session and shows it in an alert window.
    alert(SiteKiosk.Favorites.Item(1).IsFromSession);
