Balance Property
The Balance property contains the current balance.
[flt=] SiteKiosk.Multimedia.Balance
Float value between 0 and 1 that specifies or retrieves the balance.
Before using this property the first time, check the BalanceAvail property to determine whether the balance can be modified.
The following example shows the current balance in an alert window.
alert(SiteKiosk.Multimedia.Balance);
