Bass Property
The Bass property contains the current bass value.
    [flt=] SiteKiosk.Multimedia.Bass
    Float value between 0 and 1 that specifies or retrieves
    the bass value.
    Before using this property the first time, check the BassAvail property to determine
    whether the bass value can be modified.
    The following example shows the current bass value in an alert window.
    alert(SiteKiosk.Multimedia.Bass);
