MicVolume Property
The MicVolume property contains the current microphone volume.
[flt=] SiteKiosk.Multimedia.MicVolume
Float value between 0 and 1 that specifies or retrieves the microphone volume.
Before using this property the first time, check the MicVolumeAvail property to determine whether the microphone volume can be modified.
The following example shows the current microphone volume in an alert window.
alert(SiteKiosk.Multimedia.MicVolume);
