RecVolume Property
The RecVolume property contains the current recording volume.
    [flt=] SiteKiosk.Multimedia.RecVolume
    Float value between 0 and 1 that specifies
    or retrieves the recording volume.
    Before using this property the first time, check the RecVolumeAvail property to determine whether the recording volume can be modified.
    The following example shows the current volume in an alert window.
    alert(SiteKiosk.Multimedia.RecVolume);
