Treble Property
The Treble property contains the current treble value.
    [flt=] SiteKiosk.Multimedia.Treble
    Float value between 0 and 1 that specifies or retrieves
    the treble value.
    Before using this property the first time, check the TrebleAvail property to determine whether the treble value can be modified.
    The following example shows the current treble value in an alert window.
    alert(SiteKiosk.Multimedia.Treble);
