Volume Property
The Volume property contains the current volume.
    [flt=] SiteKiosk.Multimedia.Volume
    Float value between 0 and 1 that specifies or retrieves the volume.
    Before using this property the first time, check the VolumeAvail property to determine whether the volume can be modified.
    The following example shows the current volume in an alert window.
    alert(SiteKiosk.Multimedia.Volume);
