TemplateText Property
The TemplateText property returns a receipt text containing template variables.
[bool=] SiteKiosk.Plugins("SiteCash").ReceiptSettings.TemplateText
String value that retrieves a receipt text containing
template variables.
Take a look at the Macromap Object in order to expand the TemplateText property.
The following example shows the expanded template text.
SiteCash = SiteKiosk.Plugins("SiteCash");
templatetext = SiteCash.ReceiptSettings.TemplateText;
expandedtemlatetext = SiteCash.Macromap.Expand(templatetext);
alert(expandedtemlatetext);
