OnPropertyChange Event
Fires when one of the properties
AccountEnabled,
RetransferEnabled or
Volatile changes.
SiteKiosk.Plugins("SiteCash").Devices("ScriptDevice").
OnPropertyChange = handler
The following example shows an alert window when one of the mentioned properties changes.
sdevice = SiteKiosk.Plugins("SiteCash").Devices("ScriptDevice");
sdevice.OnPropertyChange = OnPropertyChange;
function OnPropertyChange()
alert("A script device property changed");
