OnBlockURL Event
Fires when an URL is blocked.
SiteKiosk.Plugins("SiteCoach").OnBlockURL = handler
obj |
BlockInfo object that contains information about the blocked page. |
The following example shows information about an URL if it is blocked.
alert("\"" + blockedpage.URL + "\"" + " is blocked");
