CreateStringTable Method
The CreateStringTable method creates a new empty stringtable.
[obj=] SiteKiosk.SiteKioskUI.CreateStringTable()
The new stringtable is empty, use the LoadFile method to load strings from a file.
The following example creates a new stringtable and loads all strings from a file.
myStrTab = SiteKiosk.SiteKioskUI.CreateStringTable();
myStrTab.LoadFile("mystringtable.xml");
