Duration Property
The Duration property contains the duration of the slide effect.
    SmoothSlide.Duration [=long]
    Long value that specifies or retrieves the duration.
    The following example creates a SmoothSlide object and displays the slide for 2 seconds.
    myslide.StartPos = 0;
    myslide.EndPos = 200;
    myslide.Rate = 100;
    myslide.Duration = 2000;
    myslide.Start();
    function UpdatePosition(pos)
