EndPos Property
The EndPos property contains the position where the slide ends.
    SmoothSlide.EndPos [=long]
    Long value that specifies or retrieves the end position.
    The following example creates a SmoothSlide object and starts the slide ending at position 200.
    myslide.StartPos = 0;
    myslide.EndPos = 200;
    myslide.Rate = 100;
    myslide.Duration = 2000;
    myslide.Start();
    function UpdatePosition(pos)
