OnStart Event
Fires when the slide is started.
SmoothSlide.OnStart = handler
The following example shows if the slide has been started or stopped.
<div id="txt" style="position:absolute;left:300;">
Slide stopped
myslide.StartPos = 0;
myslide.EndPos = 200;
myslide.Rate = 100;
myslide.Duration = 2000;
myslide.OnStart = Start;
myslide.OnStop = Stop;
myslide.Start();
function UpdatePosition(pos)
function Start()
txt.innerHTML = "Slide startet";
function Stop()
txt.innerHTML = "Slide stopped";
