OnUpdatePosition Event
Fires when the slide position changes.
    SmoothSlide.OnUpdatePosition = handler
    af_Pos Float value that contains the current position.
    The following example creates and starts a smooth slide.
    myslide.StartPos = 0;
    myslide.EndPos = 200;
    myslide.Rate = 100;
    myslide.Duration = 2000;
    myslide.Start();
    function UpdatePosition(pos)
