Position Property
The Position property contains the position of the slide.
    [float=] SmoothSlide.Position
    Float value that retrieves the position.
    The following example creates and starts a SmoothSlide object and stops it at position 50.
    myslide.StartPos = 0;
    myslide.EndPos = 200;
    myslide.Rate = 100;
    myslide.Duration = 2000;
    myslide.Start();
    function UpdatePosition(pos)
       if (myslide.Position > 50) myslide.Stop();
