Rate Property
The Rate property contains the rate of the slide effect.
    SmoothSlide.Rate [=long]
    Long value that specifies or retrieves the rate.
    The following example creates a SmoothSlide object and starts the slide redrawing it 100 times a second.
    myslide.StartPos = 0;
    myslide.EndPos = 200;
    myslide.Rate = 100;
    myslide.Duration = 2000;
    myslide.Start();
    function UpdatePosition(pos)
