StartPos Property
The StartPos property contains the position where the slide is to start.
    SmoothSlide.StartPos [=long]
    Long value that specifies or retrieves the start position.
    The following example creates a SmoothSlide object and starts the slide at position 0.
    myslide.StartPos = 0;
    myslide.EndPos = 200;
    myslide.Rate = 100;
    myslide.Duration = 2000;
    myslide.Start();
    function UpdatePosition(pos)
