RevokeCookie Method
The RevokeCookie method revokes a connection cookie.
ConnectionCookie.RevokeCookie()
The disconnecting process is started when the connection cookie is revoked, no matter how many references to the cookie exist.
The following example starts the disconnecting process directly after connecting.
myconn = SiteKiosk.Dialup.RequestConnection("reason", true, true);
myconn.RevokeCookie();
