SiteCafe Object
Main object of the SiteCafe Manager object model.
The following table lists the members provided by the SiteCafe object.
This object is available in the form of scripts when you are using the SiteCafe Manager.
Use the SiteCafe object to manage user accounts. The SiteCafe object can be referenced directly.
Before you can use the SiteCafe objects you need to call the function window.external.InitScriptInterface() to initialize the script interface.
Use the SiteKiosk.Plugins("SiteCash").Devices("SiteCafeClient") object for client functionality.
Note that this object is only available in the SiteCafe Manager.
The following example displays the SiteCafe module path.
alert(SiteCafe.ModulePath);
